2005 kawasaki kfx 400 atv wont start need help
Subscribe
Sep 13, 2009 | 02:59 PM
I have a 2005 kawasaki kfx 400 atv . A friend was riding it and it died and wont start again so all it will do now is just click but not turn over . So I replaced the battary and still wont start just clicks from the under the seat . I had one guy look at it and said the transmission is locked up said it will be like $1600.00 to fix Iam not pro at this stuff any thing would help. I also tried to push and pop the clucth but it didnt work
Reply 0
Sep 13, 2009 | 10:19 PM
Need Help
I wanted to add how can you tell if the motor locked up is it possible ? When it starts with clicking noise?
Reply 0
Sep 13, 2009 | 11:34 PM
Yea I am no expert either but when you turn your key on does your neutral light come on?
Reply 0
Sep 14, 2009 | 06:29 AM
Check the obvious things first. Main Fuse/Ignition Fuse, Spark Plug, and fuel.
Reply 0
Sep 15, 2009 | 12:51 AM
Need help
The neutral light works, I did check the fuse under the seat it is good
Reply 0
Sep 15, 2009 | 08:17 PM
Pull the sparkplug and see if it turns over.
Reply 0
Sep 17, 2009 | 12:48 AM
Need Help
Ok I checked everything to the starter it all looks good. Ok where the starer is their was a round plate that had three bolts I took that off and and this gear deal came out I tried the starer and it was working fine but the gear part the the starter turns was realy had to move I dont know where to go from here? Whats next to check or does it mean something?
Reply 0
Sep 18, 2009 | 01:30 AM
Can you start it with the recoil start?
Reply 0
Sep 18, 2009 | 09:44 AM
Quote: Ok I checked everything to the starter it all looks good. Ok where the starer is their was a round plate that had three bolts I took that off and and this gear deal came out I tried the starer and it was working fine but the gear part the the starter turns was realy had to move I dont know where to go from here? Whats next to check or does it mean something?
The z400 is known to have some starter issues. Since they were designed for MX racing at the time, the starter is very light duty and cannot take abuse. I've heard many of them going south prematurely.
The gear you pulled out is the starter clutch I believe. And it can lock up if one of those gears is sheared or even cracked. I have pulled mine out to inspect it a couple times during oil changes to check for wear because I know they have had problems.
The good news, is that you can go on Ebay and probably find a few z400 starters in real nice condition. Or call East Coast ATV and ask them if they have one. They probably do.
Make sure you replace that o-ring gasket, you don't want to re-use it.
Reply 0
Sep 18, 2009 | 09:46 AM
Quote: Can you start it with the recoil start?
There is none on a z400..... In fact very few if any sport ATVs have a recoil backup anymore...... The last one I remember with a recoil backup was the old Warrior, which Yamaha stopped putting in sometime in the early 1990s.
Reply 0
