06 750 BF Belt light on
Old Nov 28, 2009 | 06:01 PM
ridnMT's Avatar
Question 06 750 BF Belt light on
The belt light on my BF came on (not blinking) while riding,still runs good but how does a guy shut the light off???
Old Nov 29, 2009 | 09:19 AM
WPAbrams's Avatar
Default Belt light
Buy the shop manual and it tells you how to reverse the plugs on the belt housing with the key on for so many secounds . This light will come on every 100 hours. The belt should be inspected for damage every 100 hours. The belt catchs hell. If you have a repair shop or stealer near you that might be your best bet.
Old Nov 29, 2009 | 06:35 PM
harry1's Avatar
I believe the non blinking mode is more serious than the 100 hour inspection which is flashing mode of the same light... could be wrong but this is what I think.
Old Dec 1, 2009 | 10:45 AM
Hayashi's Avatar
Yes, you are wrong on that.
> Non-blinking (steady on) light is THE 100-hr inspection reminder light.
> Flashing light is the serious one because the belt switch got hit by either broken or belt with too much deflection. That's why quad goes into the limp-home mode when the light is flashing but not when steady on.
BTW, when checking, be sure to check the converter sheave surface for wear/grooves and the spider shoes clearance (all in the service manual).
Old Dec 1, 2009 | 11:45 AM
TLC's Avatar
TLC
Nyroc's ATV info website
Hope it helps.
Old Dec 4, 2009 | 06:49 PM
ridnMT's Avatar
Thanx for the help,,Just had to reset the belt light...Everything works great.
Old Dec 8, 2009 | 10:33 AM
Hayashi's Avatar
You just reset the light and didn't check out the CVT system for wear and tear?
Old Dec 8, 2009 | 10:59 AM
crazy650's Avatar
if you didn't check you could have a bad day soon
Old Dec 8, 2009 | 11:02 AM
crazy650's Avatar
YouTube - Kawasaki Brute Force belt light reset
reset light
This is what you belt may look like on the in side?
YouTube - Another belt in the Brute Force
Old Dec 8, 2009 | 02:49 PM
Hayashi's Avatar
Exactly that's my point.
If you were only to reset the light and not checking anything on the CVT, it would be easier to just put a piece of electrical tape over the belt light (if it is the steady on light for 100-hr check) since that steady-on light does not affect the running condition.
