symptoms of a bad cdi box
Old Jul 26, 2017 | 12:15 PM
Sounds like some one took the cheap way out. The black kill wire from the cdi also ties into the left control switch and the ignition switch kill circuits. The problem could be in either of those,left control switches were really bad on this,or the black kill wire from the cdi has shorted out internally and the po was too cheap to get a new one.Just toggled it instead.If you want to fix it right go through the ignition checks and wiring diagram in the manual to help track down where the problem is.2002 Polaris Sportsman 500 Service Manual PDF Download
Old Jul 26, 2017 | 12:21 PM
Krazzytaker's Avatar
It doesn't have a start button it's all in the key switch. I do have a service manual and I will start with that thanks for your advice.
ReconBayou
Oct 31, 2022 05:37 PM
Cummins Driver
Sep 11, 2019 01:22 PM
merryman
Jan 19, 2016 04:29 AM
Ward660R
May 5, 2003 04:47 PM
cowboy
Nov 10, 2001 03:46 PM
