1986 300 Bayou running hot
Old Jul 3, 2012 | 09:00 AM
bvolks's Avatar
Afterdoing a bit more reading I think I'll check my float height. I wish I'd have thought of that yesterday when I had it all apart.
Old Jul 3, 2012 | 12:41 PM
Jaster94's Avatar
check your fuel tank vent also. that way you can eliminate the possibility of vacuum locking the tank.
Old Jul 10, 2012 | 03:00 PM
desjardins2012's Avatar
Default still going on?
Hey - back to the forum I thought I would add two cents again to this topic regarding the bike reving on it's own I had a run in with a ditch the other day, was turning and bike went off on it's own took me right down a ditch so I decided enough was enough I had to figure this out... something so stupid and it could be on yours too...
looking at my throttle cable it was wired ontop of the handlebar when I made sharpe right turns it pulled the throlled sending it whereever I was pointing...
lesson learned, issued fixed
Old Jul 11, 2012 | 09:26 AM
bvolks's Avatar
That was the problem with it stalling. Thanks.
Old Jul 11, 2012 | 12:21 PM
  #15
Jaster94's Avatar
you are most welcome! glad everything is going your way!
Old Jul 18, 2012 | 09:38 PM
  #16
bvolks's Avatar
Originally Posted by desjardins2012
Hey - I too have the same bike 88 however and experience the exact same problem although I'm yet to consider it a problem - well atleast the heat anyhow.
I'm trying to figure out whats going on with the idle also for me it's not only in nutural but also from time to time in gear it tends to rev out and take off on it's own.. def carb issue I'm going to be plugging into this project this weekend I'm thinking i'm sucking in air from around the intake - as I just had the carb rebuilt so I can't see it being inside my carb
but yes I to have the heat that I ride with my one leg kinds pointing out and the idle issue... be nice to see someone's feedback on this makes me feel a little better knowing it's happening to you also :P
Have you tried adjusting your valves? I did mine a couple days ago and the high idle/ revving up problem went away. It starts a lot better now and I think it's even running cooler now too.
Old Jul 19, 2012 | 11:20 PM
  #17
rv's Avatar
rv
Originally Posted by bvolks
I finally got the old Bayou trail legal this weekend and put about 60 miles on it in 25*C + temperatures and it seems to be working fine and doesn't get much hotter than my brother's Yamaha so I'm not too worried about it running too hot and destroying something anymore. We had it out after dark and the exhaust definitely isn't glowing red. However, it does stall occasionally at higher rpms like it's running out of gas but starts right back up and runs fine. I took the carburetor apart and cleaned it again and pulled the tank and removed the on/off/reserve valve and gave it a good cleaning but it's still doing it.
iv had that hapen to me when the air screw is out to far it should only be out about 1.25 turns aprox
jgreerberube
Jun 21, 2015 02:27 PM
bvolks
Jun 13, 2015 08:14 AM
TJM
Jun 11, 2015 01:28 PM
blasterguy
Aug 9, 2000 04:59 PM
Smokinthebear
May 7, 2000 08:01 PM
