2006 Brute Force jetting help
Old Apr 20, 2013 | 06:15 PM
jsimonh's Avatar
Default 2006 Brute Force jetting help
I just put a HMF slip on and K&N filter on a completely stock 06 650 Brute Force today. It runs really well but pops a lot on deceleration. I've had atv's that have done this in the past, but it seems excessive. I went with 145-148 which is a little bigger than what HMF recommended. I read where popping could be a lean condition so I went to 148-150 and the pops got worse. I haven't messed with needle setting, pilots, or the fuel/air screw becasue I didn't see it anywhere on the bottom of the carbs. I looked at the plugs and they were pure white and looked a little lean, but going up made it worse so I'm confused. I've got a DS650 with a big lectron carb, but this 4×4 is kicking my butt! Any help would be appreciated.
Old May 31, 2013 | 09:25 AM
Jschmidt3's Avatar
This was happening to me after i put my muzzy system on. Turns out the cvt intake pipe wasnt connected to the airbox so i was sucking in way too much air.
I would suggest going up on your pilots and maybe shimming your needles.
ReconBayou
Oct 31, 2022 05:37 PM
Pgbama11
Jan 16, 2016 08:19 AM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Pgbama11
Sep 10, 2015 08:20 AM
