Air box mod
Old Mar 19, 2014 | 12:58 PM
Kawasakiman227's Avatar
Default Air box mod
What does everyone think about the air box mod or just taking the lid off and if I would need to rejet
Old Mar 19, 2014 | 01:57 PM
sprinklz's Avatar
probably need to rejet
just go full stage 1
Old Mar 19, 2014 | 02:29 PM
Scott_Tx's Avatar
oh yeah, going to need a new cam and change the sprocket ratios too.
which four wheeler are we talking about anyways?
Old Mar 19, 2014 | 02:43 PM
sprinklz's Avatar
cams are spendy, im rebuilding my engine this summer and im only putting in a higher comp piston, not going to ever do cams
Old Mar 19, 2014 | 03:39 PM
09 kawasaki bayou 250, just looking for some ways to get a little more low end power for wheelies without spending $200
Old Mar 19, 2014 | 05:00 PM
Scott_Tx's Avatar
oh. you and your wheelies. strip all the weight off the front. put some more on the back. pray.
Old Mar 19, 2014 | 05:18 PM
Ok thanks I can get it up in first but want to in second without going up a hill my friend makes fun of me because he can do them in 3rd on a 1994 timberwolf
Old Apr 13, 2014 | 02:45 AM
kawipolaris's Avatar
you could try changing the gearing if you want and you will definitely be able to do 2nd gear wheeliie with different gear ratios for more low end power but of course you lose top speed but if you dont want to sacrifice that just do what sprinklz said just go full stage 1 get a performance exhaust, K&N filter, rejett, and instead of taking your airbox lid off i would suggest using uni air box vents Dirt Bike UNI Air Box Vents - 6 Pack | MotoSport comes with 6 and they are about 1 inch in diameter ive heard they help a lot with more air flow but dont let more dirt in.Its definitely safer than drilling holes in your airbox or just taking the lid off. Good luck
Old Apr 13, 2014 | 03:32 AM
Scott_Tx's Avatar
kind of hard to change the gear ratios, its shaft driven.
Old Apr 13, 2014 | 04:14 PM
sprinklz's Avatar
you add/remove a tooth on the drive sprocket
and/or add/remove a few teeth on the rear sprocket
thats how you alter your final drive ratio
more teeth on the front ups your top speed at loss of tourqe and visaversa
more teeth on the rear ups your tourqe at the loss of top speed and visaversa
larger tires does the same as more teeth on the front sprocket
and smaller tires does the same as more teeth on the rear sprocket
