Electric start problem someone help!
Old Feb 20, 2016 | 05:44 PM
Ross.B's Avatar
Default Electric start problem someone help!
Hey guys I have a Kawasaki 220 bayou and I have been just using the pull start since I bought it because I didn't want to buy a battery. The guy I bought it off of said the electric start does work. I hooked jumper cables up to a battery and tried starting it. It didn't make any noise when I pushed the botton but the neutral light turns on and headlights work. Why won't the electric start work when everything else does? And no there was no clicks or noises. Thanks
Old Feb 21, 2016 | 10:46 AM
Ross.B's Avatar
Default Never mind
I think it was just the battery. It did not have enough juice. I had jumper cables hooked up to a battery that was not in a car. I think it only had enough juice to turn lights on considering it did nothing when clicking electric start botten. If there were any clicks it could be a number of different things wrong but nothing. I ordered a new battery and will see how it works then
Old Feb 22, 2016 | 07:13 AM
Fasteratv's Avatar
I hope that battery takes care of the problem for you.
Old Feb 23, 2016 | 08:25 PM
Kymco 450i's Avatar
Was the kill switch turned on? Check all your electrical connections....if not used for a while they may be corroded. Wire brush until shiney the put back together, each connection needs to be taken apart and cleaned.
Old Mar 9, 2016 | 11:34 AM
Ross.B's Avatar
Default Fixed it
It was not the battery that fixed the problem. It was the starter circuit relay was no longer good.
Old Mar 9, 2016 | 11:47 AM
Fasteratv's Avatar
That's great! Glad you figured it out and communicated the fix....
keith2580
Apr 12, 2021 05:27 PM
Danielpschlier
Jan 7, 2016 08:32 AM
trouttracker
Jan 3, 2016 04:48 PM
Mark Smith
Dec 10, 2015 12:43 AM
