Help, oil is going everywhere on my 220.....
My 220 is just about falling apart. There is oil comming out of the gasket on the cover that is over where the driveshaft comes out, and on the opposite side somewhere. There is also oil comming out of the bottom of the rear brake drum, I'm not sure y though. By the way, it only leaks when its running. Is there a way I can fix it or do I have to take it to the dealer? And, how much is this gonna set me back??
Man, that sux hard! I dont have any help for you, as if it seems that serious, it might be something you could consider to take in and get it looked at.
My 220 has leaked oil out of the top head gasket, but that only happened after I spent 2 hours in 90 degree weather pulling a loaded screen behind the quad. Overheated the thing a bit and the gasket became a little too pliable, but tightened down the bolts on the engine case to spec and hasnt leaked anything substantial recently.
