Mojave IDS2 Pipe
Old May 27, 2002 | 12:48 AM
MOJAVE02's Avatar
can the IDS2 Race Core exhaust system be used on a stock engine, or does it need be used on modified engines(cams, carb, porting, etc..)? what kind of power gains will i get with this system and a K&N Power Kit? also what jetting works best with this exhaust?
Old May 27, 2002 | 12:52 AM
mojaveman1's Avatar
the ids2 is in my openion the best pipe for the mojave and will work great with the mojave it boosts power and throttle response with the jetting try a 134 first it seems to work the best on piped mojave
then if you want more power get the uni clamp on and a 13 tooth front sproket
both are cheap but then you need to get like a 138 or 140 jet
it makes it a totaly different machine
Old May 27, 2002 | 09:19 PM
Chris142's Avatar
Check out my post on 5-23.
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
bvolks
Sep 13, 2015 12:57 PM
