Advise on tire pressure
Old Oct 6, 2002 | 10:50 AM
ConMan's Avatar
I have a 650 with 26" bearclaws. Am getting ready to do some muddrunning and need some advise. I know a lower tire pressure gets you some traction, but a higher pressure would help with clearance (maybe only a little but I would like all that I can get). Could you fella's give me some advise as to high or low pressure and why.
Would appreciate it alot!
Old Oct 6, 2002 | 04:10 PM
ConMan's Avatar
anyone know ANYTHING about this?
Old Oct 6, 2002 | 08:56 PM
Dextreme's Avatar
I would just run about 4 psi all the way around in most conditions. In the sand, I drop down to 2 lbs. If I am cruising around the neighbor hood on asphalt, I pump up the fronts to 8-10 lbs so it is easy to steer.
Old Oct 6, 2002 | 09:19 PM
Metallikev's Avatar
I run 4lbs all around..takes a little more to steer but makes the ride soooo much smoother.
STLyamwar
Jul 25, 2020 04:44 AM
mtdewmn
Jan 19, 2017 12:13 PM
89Lt250r
Sep 7, 2015 07:53 PM
Stirling
Aug 9, 2015 01:49 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
