Shims:
Old Oct 22, 2002 | 12:21 PM
SandBags's Avatar
Default Shims:
This has probably been discussed before, so please forgive me.
How many different size shims are made to adjust the driven pulley on the 650 and what sizes are they? If you could list the part number for each shim that would be great. ……….Thanks
Old Oct 22, 2002 | 12:54 PM
92LT's Avatar
Default Shims:
There are 4 shims. Don't remember them off hand, so you should do a search here or go to www.buykawasaki.com and look them up.
Old Oct 22, 2002 | 12:57 PM
trx450's Avatar
Default Shims:
SHIMS= .6mm/.8mm/1.0mm/1.4mm. They are @$5.00 EA from the dealer. <www.buykawasaki.com> has the P/N's.
Old Oct 22, 2002 | 01:58 PM
SandBags's Avatar
Default Shims:
The .08 shim must be the new size Kawasaki came out with. Buykawasaki does not list .08 size and my dealer also can't find the part number for it. Thanks for the quick response guys.........
Old Oct 22, 2002 | 02:50 PM
92LT's Avatar
Default Shims:
The .08 shim info: Look on buykawasaki.com and look under the 2002 prarie 650 B1 model
"92026C Part #92026-1617 Description:SPACER,T=0.8 AR "
hope this helps.
Old Oct 22, 2002 | 03:18 PM
SandBags's Avatar
Default Shims:
Thanks 92LT. When I looked at buykawasaki I was looking at the 03 parts diagram.
