p650 EBC noises? just wondering.
Old Oct 25, 2002 | 09:50 PM
trailburner's Avatar
Default p650 EBC noises? just wondering.
when ever I throttle or touch the back brakes, they clatter quite a bit. Is this the case with all of your quy's p650s? I took it in and the tech didn't know what it was so he assumed it was normal. It kind of bothers me and I would like to know if I should just learn to ignore it or if there is something whrong?
I am planning a ride tomarrow but I'll cancel it if you tell me that the sound isn't normal.
thanks for any imput.
Old Oct 25, 2002 | 10:25 PM
jjs3788's Avatar
These things make all kinds of strange noises. After a while you wont notice them.
Old Oct 26, 2002 | 12:10 AM
Kawi650's Avatar
check your front bearing on your clutch if you hear it when the engine braking cuts in.
Old Oct 26, 2002 | 01:42 AM
thanks for the replies!
Old Oct 26, 2002 | 09:11 AM
roscoe69's Avatar
Trailburner
My kawi produces a lot of odd noices lately. Im used to the usual klunks, clatter, whirrs and assorted noises. Lately in low range when i let of the throttle the ebc goes into the mode of not knewing where to be, engaging and unengaging at a very high rate . It is olso starting to do this when i need the engine breaking, desengaging,reengaging, turning me loose on a hillside. This is not noticable in high range, probably the set up in the monitoring device. My belt is old over 2500 miles. Will get into that nex week.
Raymond
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
firsttimerider
Sep 20, 2015 09:07 PM
