Lakota clamp-on filter
Old Nov 26, 2002 | 11:18 PM
ripenkawi's Avatar
Default Lakota clamp-on filter
Ive seen alot of posts about the mojave clamp on filter, but has any body put one on the Lakota?
are they same set up ? same sizes?
Old Nov 27, 2002 | 11:38 AM
stebob's Avatar
Same set up, different sizes, however. The Mojave uses a 34mm carb., while the Lakota uses a 32mm. The OD of the bell on the Lakota carb is 1 15/16". You will need that when you order the filter. This should result is quicker throttle response and a little more power throughout the rpm range. However, you will be sacrificing water and mud protection. I have, however, seen a clamp on go through everything I did, about 2 1/2 feet of water and not even hiccup! So.... I plan on doing this very thing to mine in the near future.
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
