Just Got The Mud Lite's, Here Are The Specs
I never thought about that. Is it much of a prob ? I havent heard anyone mention that before.
that would be wonderful..
djnemesis@clanradium.com
How tall are the lugs on em? I'm really wanting to get some new tires and I just don't want to go with anything too big/heavy like the vamps.
If you don't mind me asking, how much did you pay for the mud lites?
#18
jjs3788, what psi are you running to make these tires 27"? I have yet to see a set of tires that are what the advertise. I havent seen the Mudlites though. Some say the Outlaws are what they say but I never seen those either.
#19
I have 7psi in the front and rear. That is what it says on the side to run them at. When I first got them the rear measured a little taller that 27 1/8 but the width was only 11". I thought that was kinda far off, so I called ITP and talked to a guy name Brett. He said check the air pressure and he thought I would find it was too high. This is my first set of aftermarket tires so I didnt really know what to expect. It turns out when they mounted them they put around 14psi in all the tires. I had just assumed that they would be at the correct poundage since it written right on the side of the tire. So, when I let the air out to 7psi they filled out 1/2 inch. I thought that was close enough. I was mostly concerned with the height. I did learn that I have to check everything I buy in the future.
I am goin trail riding tomorrow, so I will let you know how they do. We still have about 6 1/2 inches of wet snow here.
#20
Lugs are 1 1/8 tall. I got them from 4atvtires.com for $540.00. The pictures are on the way.
