CAN I USE OTHER OIL FILTERS ON 03 650
Old Dec 28, 2002 | 11:46 PM
GILTYLER's Avatar
Default CAN I USE OTHER OIL FILTERS ON 03 650
I want to find a less Exspensive filter Than the kawi filter.
Old Dec 29, 2002 | 12:04 AM
nyroc's Avatar
All oil filters listed below have the right threads for the 650. the 650 does not have the same thread depth problems as many other quads have, so I think all of these filters will work well. Look at the filter mount area, then look at the filter before you buy it to be sure that you won't have any thread depth problems.
Motorcycle-Specific Filters - (About 2.5 to 3 inches long)
Purolator Motorcycle ML16817 about $6.00
NAPA Gold 1358, Carquest 85358, WIX 51358 about $7 to $8
AC Delco PF2135 about $10
FRAM PH6017A about $7
STP SMO-017 about $6 Autozone
Automobile Filters - (About 3.5 inches long - fit reference 1994 Mazda MX-3, V-6 Engine)
Mobil 1 M1-110 about $10
Bosch 3323 about $5
Purolator Pure One L14620 about $6
NAPA Gold 1356, Carquest 85356, WIX 51356 about $6
Deutsch D-370 about $4
AC Delco PF-2057 about $6
Motorcraft Long Life FL-821 about $4
STP S-02867 about $3
FRAM, Castrol, Penske 7317 about $3
Automobile Filters - (About 2.5 inches long - fit reference Mazda RX-7 and Miata)
Bosch 3300 about $5
NAPA Gold 1365 about $6
Purolator L14622 about $5
AC Delco PF1237 about $6
STP S-02876 about $3
FRAM PH6607 about $3
Old Dec 29, 2002 | 12:48 AM
GILTYLER's Avatar
WHAT Filter is every one using 03 p650
Old Dec 29, 2002 | 11:57 AM
Lightman's Avatar
If you can fit it, the Mobil 1 M1-110 is the best filter on that list. If that does in fact fit, run it. It actually is the same size filter as a 1996-00 nissan pathfinder takes. I changed the oil in my friend's yesterday, and kept ragging her because her truck takes the same tiny oil filter as a p650. They are tiny, but the synthetic media really is much more efficient at trapping engine wear metals and contaminants. I think it was $10. I say don't skimp on the quality of your oil filter!! You didn't skimp on the quality of your atv, give the engine the best. I guess it kinda depends if you're the kind of guy who drinks tap water and doesn't take vitamins, or if you're the bottled water/centrum guy.....lol....
Also Amsoil makes their high quality super duty oil filter for the p650, the sdf13. Not sure if they make a dual stage foam air filter for it yet, but they are high quality filters. I have one in my TDI diesel jetta ('02) and my silicon levels are always extremely low in my oil analysis reports.(good air filtration).
Old Dec 29, 2002 | 07:00 PM
roscoe69's Avatar
I use baldwin # B1400 from Ackland Granger
No problems , its a crossover # from one of the filters on nyrocs list
Old Jan 2, 2003 | 04:29 PM
1BAD650's Avatar
it is the same filter that fits a mazda miata with the 1.8 liter engine
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
