I`ve cured my paralysis from analysis.
Old Jan 8, 2003 | 08:27 AM
EasterEgg's Avatar
Default I`ve cured my paralysis from analysis.
The way I was able to do this was to just go out and buy an 03 Prarie 650 in aztec red for $6400 + now I`m as healthy as any other 650 owner[img]i/expressions/face-icon-small-happy.gif[/img]
........but now I can`t sleep[img]i/expressions/face-icon-small-shocked.gif[/img]
Questions about tires I will be purchasing tires only not enough $ left for wheels too. I`m looking at the Mud Lites or 589`s in 26. Will these fit on the stock wheels or do I need to stay with 25? The dealer says I can`t.
This dealer sells Kaw, Honda and Yam they said they`ve had more Grizzlies in the shop with mech problems than the others. Also a couple of Rincons with trans problems (not shifting from 2nd to 3rd) and Praries had the least problems.
But the speed, sound and sportiness is why I chose the Prarie 650.
Old Jan 8, 2003 | 08:34 AM
trx450's Avatar
They should fit fine. I have a TON of clearance with the Radial Outlaws 26X12X12, and "C" Series wheels. The "C" has 1" POS. offset.
I see you are from "nyroc" country. He is a great source of info. Check out nyroc's ATV Website.
Old Jan 8, 2003 | 09:19 AM
EasterEgg's Avatar
Yes I`ve seen NYROC`s site even if you were`nt concidering a P650 you will be after reading his site. Maybe we`ll get together and ride sometime (NYROC) even you TRX I venture to Wayne at least once a year typically in the fall.
I`m more concerned with the wider aftermarket tires fitting on the stock wheels than the outside clearance. I assumed this would not be a problem.
Old Jan 8, 2003 | 09:29 AM
trx450's Avatar
EasterE.--- DO let me know when you come out to WNF in Ohio. I'll show you around. I "live" there, most EVERY weekend!!!!!. We go to Hat/McCoy 3-4 times a year. H/M is like WNF on steroids X 30!!!!!!!!!!!!!!!! AWESOME!
Old Jan 8, 2003 | 11:01 AM
Chuckybrown's Avatar
I have 26" 589 M/S's on mine. They fit fine, never rub, etc. In fact, they are the exact same height as the stockers. Click on the "my pics" link in my signature for a look-see.....
Front: 26X10X12
Rear: 26X12X12
Chucky
Old Jan 8, 2003 | 01:05 PM
EasterEgg's Avatar
Thanks Chuck
Looks good!! I`m going to go with the Mud Lites though in the same sizes.
BTW Where did you get those hand guards and who makes them.
Thanks
Old Jan 8, 2003 | 03:33 PM
Maier Hand Guards
Do a search using "ATV HAND GUARD" as keywords.
Chuckybrown
Buckweet
Mar 24, 2002 11:50 PM
