BAYOU 300
well assumeing its the same as the 650's front diff set-up, it will lock the rear wheels so they wont slip like they would with a normal non-lockable diff. and no its not 4x4, but they do offer a 4x4 version its just not selectable. clear anything up?
Slip-type differentials are designed to allow one wheel to turn slower or "slip" while the opposing wheel rotates faster when making turns. It eliminates the "push" you feel when trying to make a turn on an ATV that doesn't have it. However, the feature can be problem when you get stuck such that one wheel looses traction. Torque is taken away from the wheel with traction and placed on the opposing wheel where it spins uselessly. By allowing the rear wheels to be located at the differential, both wheels receive equal torque no matter what.
I have a 300 4x4 Bayou. It is a very reliable simple machine. It does not have a selectable 4 wheel 2 wheel drive. It is full time 4 wheel drive. I does however have a high/low semi-auto transmision. In low range it will pull logs or just about anything. For a full time 4x4 it is very 'light' on the steering, you can't hardly tell it is a 4x4 machine.
i have a 1986 kawasaki bayou 300. when i downshift to first it slips into reverse without touching the reverse lever. anyone have any ideas for a cheap fix, without having it put in the shop. i dont have an owners manual either so thats no help. thanks for ANY advice!![img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-smile.gif[/img]
Yes your reverse cable isn't releasing. You can try cleaning around the cable to make sure grease and grim doesn't have it fouled. You can avoid the shift to reverse by maually twisting the reverse lever back around after putting it in reverse.
