KFX400 or Predator 500?
Old Feb 22, 2003 | 09:09 PM
iszdan's Avatar
Default KFX400 or Predator 500?
The question was which is better and was asked in the kawasaki forum. We all know the pred is better all around then the Z or KFX.
Its ok guys you can admit it.
Old Feb 22, 2003 | 09:13 PM
BarelyLegal's Avatar
That's kinda what I was saying. If you're just going to get a quad and want it to do most things well without modding it at all due to budget or whatever, the predator is fine. If you are going to change to Axis shocks, wider arms, bore it and stuff then everything you get with the predator would just be coming off anyway, so it doesn't make sense to buy it for the parts on it really if they are coming off to get the first rate stuff. The only reason I can see right now are 100 more CC. You can bore it like anything else so a Z will never match its' displacement.
The Z400 is incredible with just a few mods. 40 lbs lighter makes a big difference and reverse is cool.
Old Feb 23, 2003 | 01:06 PM
pvtCowboy's Avatar
I think that when you consider that the Pred has $1500 worth of tires and shocks from the factory and 100 more ccs you can't go wrong.
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Lou Domenech
Sep 11, 2015 06:35 PM
Elkaholic
Sep 6, 2015 02:44 PM
Brandon400
Sep 5, 2015 08:44 PM
Jul 29, 2015 01:24 AM
