oil missing
Old Mar 13, 2003 | 10:41 PM
littlecanuck74's Avatar
Default oil missing
having a problem with oil
had choke cable replaced as it was sticking also found oil in the air box at sametime everything seemed to be good until now checked the oil after a long run the other day and was down a half litre took it to the shop they are telling me there is no problem that they can see
please advise of known problems
Old Mar 13, 2003 | 11:19 PM
Kawi650's Avatar
Default oil missing
are you in the breakin period? there's an overflow for the oil into the airbox. Did they add oil or did you check it before riding?
Old Mar 13, 2003 | 11:22 PM
Default oil missing
i have about 2800kms on now
i did check it before going out for the run as well yes had to add a little
Old Mar 14, 2003 | 12:37 PM
83bigred's Avatar
Default oil missing
Anyone else have an idea or heard of this?
Old Mar 14, 2003 | 02:22 PM
SASCACH's Avatar
Default oil missing
Have you changed oil lately??If you get just a little to much oil in them it will blow it out the breather. Another thing is the chokes can still stick evin with the new choke cables installed. Did you get the new sprinsgs when you got the new cable? If the oil is in your air box it came from your crank case vent, this can be caused by a few things one can be the sticky choke, too much oil, too light of oil, not the rite kind of oil (has to have the anti foaming agents). If it's not related to the type and quantity of oil you use it is likely one of your chokes stuck on a little. This washes your cylinder with exsess fuel and causes more than usual blow by which in turn pushes the oil from your crank case to your airbox. Could be what your problem is.
Old Mar 14, 2003 | 02:34 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Default oil missing
What kind of quad do you have????
Is it chain driven?
Old Mar 14, 2003 | 02:45 PM
83bigred's Avatar
Default oil missing
Bing: He has an 02 P650.
Wouldn't the choke sticking a little cause it to run rough? As far as I know, it runs fine. Since having the new choke cable installed, you have to manually hold the choke lever open, other wise, it closes, kinda like the throttle lever, know what I'm saying? I would assume there is some heavy duty springs installed to make it close on it's own. Every time out (avg 50 kms a trip) you have to add oil when done riding, doesn't appear to be smoking blue out the exhaust either.
How would you check to see if the choke is sticking?
Old Mar 14, 2003 | 02:46 PM
83bigred's Avatar
Default oil missing
Oh yeah, forgot to add, he's running Castrol 4 stroke 10W40 or 30.
Old Mar 14, 2003 | 03:23 PM
Default oil missing
my bike is a 02 650
and the oil i am using is castrol 10/40 4 stroke
i never put too much in pretty careful not to over fill
Old Mar 14, 2003 | 06:01 PM
Kawi650's Avatar
Default oil missing
is castrol oil the problem is it designed for vtwin engines? Also I heard valves that are out of adjustments go thru the oil on vtwins.
