Oil /cooling flush bayou 220?
Old Mar 30, 2003 | 10:55 AM
northernharrier's Avatar
Default Oil /cooling flush bayou 220?
Greetings:
Would there be a flushing agent for an atv engine?
4 stroke air cooled SOHC engine.
Ex. remove the oil , and oil filter, reseal the motor and add the liquid cleaer , then run the motor for set amount of time. All in order to cycle through the entier motor. Then drain the cleaner, put in new oil filter,
add new oil run engine to lube all parts.
Granted it would not be as good as manualy disaasembling & cleaning the motor.
There does not apear to be any sludge, However it would be nice to have some better oil flow.
Any thoughts?
Thank You
P.S> Basicaly the oli cleaner would be a CCC version for the oil system.
Old Mar 30, 2003 | 07:04 PM
raptorkilla's Avatar
If i was doing that I would go to wal mart or autozone and buy some cheap oil. Then I would fill the atv with the cheap oil and run it for a set time such as a few hours. then I would drain the old oil and refill. Repeat until the oil is clean and new looking after a few hours of riding
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
wendal
Sep 15, 2015 01:50 PM
rcappie4
Sep 9, 2015 07:04 PM
