Predator 90 cdi box
Old Sep 12, 2003 | 11:36 AM
Scramblur50's Avatar
Default Predator 90 cdi box
yes.. cut that green wire, and it'll open up the revs. Ours was about the same as the stock CDI when teh wire wasn't cut.
Bryce
Old Oct 9, 2003 | 07:03 PM
Cantstayoutofmud's Avatar
Does the scrambler cdi have a green wire overlaid with plastic, I found one on ebay but not sure if it is correct[img]i/expressions/face-icon-small-cool.gif[/img]
Old Dec 30, 2003 | 03:26 PM
Guys,
I bought the last CDI off of EBAY the guy has, this is the same one scrambler50 has been talking about.
I think it is a 2001 scrambler cdi
Part#30410-152-000
Package 0450722
I have read forums were guys have had trouble installing these things, but if you disconnect your battery before making changes
you shouldn't have problems from things arcing etc.
I understand the green wire should be cut, now is there a grey wire you do not connect
Just want to make sure I dont screw something up!
Any input is appreciated Scrambler 50 or anyone else!
Can't want for some snow to play in[img]i/expressions/face-icon-small-cool.gif[/img]
Old Dec 30, 2003 | 03:40 PM
I'm at work right now, so I don't have the specifics of how I wired it up.. but the green wire you cut to let it rev wied open (I just taped the ends up). The grey wire from the throttle control in the wiring harness is left disconnected with this new CDI. The big plug plugs into the o plug on the CDI.. the other 3 wires I don't remember how they hook up... on wire will only hook up to the corresponding wires on the CDI box, and then there are 2 left... try them one way.. if it won't work, try the other way (I don't think the colors matched between the harness and the CDI).
Bryce
Old Jan 31, 2004 | 08:58 AM
  #15
bmiliate's Avatar
I just bought a 2004 predator 50. Can I just cut the CDI green wire to open the revs? Is there any downside, like overrevving the motor?
Old Feb 3, 2004 | 01:02 PM
  #16
You need to get a CDI from an earlier model sportsman or scrambler 2001 or older, then yes you just cut the green wire.
There 100 bucks from the dealer use the part number list earlier in this forum. If your lucky you can get one from ebay.
What this does is lets the motor go from approx. 7200 rpm to 9200, you will not have a rev problem. This takes a whole 5 minutes to swap out.
This allows your 2 stroke to run the higher revs were it likes to. The next step is a pipe and re-jetting, then sproket and clutch tweaking if you like.
Good Luck
Old Feb 4, 2004 | 03:04 AM
  #17
bmiliate's Avatar
Thanks, Cantstayoutofmud - great info.
Is the only purpose of the CDI to limit revs, or does it manage timing, etc.?
Thanks,
Brian
Old Feb 4, 2004 | 09:40 AM
  #18
bmiliate's Avatar
jr13,
Wanna make sure I'm looking for the right p/n for the CDI. I've seen a 0450722 for the 2001 Sportsman 90 and a 0450975 for the 2001 Scrambler 50. I'm not a mechanic, so I'm looking for the easiest swap that will free up the revs - no wiring harness changes, etc., if possible.
Also, is the installation just unhook the battery and connect the wires? Anything I could permanently mess up?
Thanks for your help,
Brian
Old Feb 4, 2004 | 11:04 AM
  #19
Your CDI is your ignition module ie. Capacitor Discharge Ignition
I used 0450722, this is the same one Scrambler50 used for his 50.
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Elkaholic
Sep 6, 2015 02:44 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
