OLD LT 50
Old Nov 11, 2003 | 01:23 AM
trailride's Avatar
Default OLD LT 50
Anyone know where i can find parts to rebuild this old lt 50 i got. the little thing just wont run. wont even start getting fuel getting spark but i heard that this engine is a piston port engine, and if the main bearing gets any slop in it it will be out of time . what do you guys think?
Old Nov 11, 2003 | 02:09 AM
SPORTYatvs's Avatar
Default OLD LT 50
Does anyone know how i can make my polaris x scrambler 90 go faster? and if so how? thank you
Old Nov 12, 2003 | 06:15 AM
moonshiner's Avatar
Default OLD LT 50
A couple offdegrees won't stop it running..clean out the carb..clean out the exhaust..stick in a new sparkplug and pull on the rope..If it won't fire manually choke the intake with your palm and pull a bit more..no go check your spark plug it should be wet by now...weve put a power drill on the crank once to free things up just take of the pull cord cover and theres a big nut.
