Lt 80 wont start
Old Aug 24, 2004 | 07:32 PM
450Rutmaker's Avatar
Default Lt 80 wont start
NO you miss understood me. It is getting spark. The gas on the other hand is kinda dribbly not really solid. I tried cleaning the turn valve under the tank but it didnt do omuch.
Old Aug 24, 2004 | 09:41 PM
confusedbuyer's Avatar
the valve is called the petcock. it needs vacuum to draw gas in the "on" position. try it in the "prime" position to see how much gas flows. It should free-flow in "prime".
to check the compression, you need a compression gauge. it threads into the spark plug hole and then you crank engine to see what your compression reading is. they're kinda expensive to buy, but lotsa places rent them.
Old Aug 25, 2004 | 01:20 PM
iLL's Avatar
iLL
I have a problem with my LT80 Starting too but mine doesn't even crank i've checked the fuse (i could only find 1) and everything is good i also don't have a key so i guess what i'm looking for is a way to "hotwire" it. i got this from my friend its been sitting for about 1 1/2 its a 92'
Old Aug 26, 2004 | 12:58 AM
quadduck's Avatar
Disconect the igniton switch and replace it with another or work in a tog switch. If you want to make sure it will turn over you can bypass the ignition and put power directly to the starter to see if the motor is froze up.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
