Lt50 Gearing
Old Nov 2, 2004 | 07:16 AM
nicks3's Avatar
Default Lt50 Gearing
My young son has started riding our old Suzuki LT50. The problem is that as the bike is getting a little tired the throttle limiter has to be out a little further than I would like to be able to haul him off from a standstill - but once it gets going it is faster than I want. I thought about buying new front and rear sprockets to give it more go initially but to lower the top speed. Has anyone done this and if so where can i get the parts?
Cheers, Nick
Old Nov 3, 2004 | 12:03 AM
13speed's Avatar
Try going to a larger rear sprocket. WRH Racing should be able to help you or direct you to someone who can. My son rode an lt 50 for awhile, so I know what youre going through.
Old Nov 3, 2004 | 06:47 AM
nicks3's Avatar
Standard bike has 37 teeth rear sprocket. Have just ordered a 43 teeth one to lower the gearing which should solve the low speed pickup/high speed problem.
Old Nov 3, 2004 | 08:38 PM
13speed's Avatar
That should be a good start. If you need a little more, go one tooth smaller in the front. Hopefully you will have enough chain slack to run the bigger sprocket. You may want to look into removing ( if you havent already ) the exhaust restrictor. When I removed ours it gave the bike a lot more low end power. The difference to the over all preformance with it and the carb restrictor removed was night and day.
Old Nov 30, 2004 | 12:11 PM
nicks3's Avatar
When you say carb restricto do you mean the one in the intake and if so did you have to put a larger main jet in?
Old Mar 28, 2005 | 12:42 PM
Duneaddict's Avatar
I'm having a heck of a time finding anyone that carries sprockets for these little things...
I tried to contact WRH but no luck.
I have the same problem of sluggish takeoff, and way too fast on the top end. Gearing would make a huge difference if I could just find a parts supplier.
Any ideas?
Old Apr 7, 2005 | 11:14 AM
Duneaddict's Avatar
Anyone?
Old Apr 7, 2005 | 07:04 PM
minilt's Avatar
you would want to try sprocket specialists.com 1-800-782-8200 they can make the rear sprocket for you for about 35.00 dollars. for more take off you would want to go bigger in rear
Old Apr 8, 2005 | 10:16 AM
Duneaddict's Avatar
Thanks!!! That's all I needed was a place that can fix me up!
Old Apr 18, 2005 | 09:50 PM
maggiesboy's Avatar
"One Wheel Short"
suzuki / kawi 110's use the same rear sprockets on the "older" 84-87 LT50's, thats what we run. Also remove the pilot jet restrictor .38 size that piggy backs the stock sized 15 pilot. I have my boys race bike (86 LT50) on C-12 race fuel with motul 800 mixed at 40:1, 15 pilot, 67.5 main jet, 2.5 turns out on the screw. Gearing varries from 11-16 on the counter shaft to 33-37 on the rear. It has a uni filter and a Graydon pipe. This little bike rips!
