LT80 Starter Motor
Old Dec 30, 2004 | 03:13 PM
confusedbuyer's Avatar
Default LT80 Starter Motor
bench test it first before putting it back in. put it in your Record vise, and put electricity to the hot lead. you'll have to make sure you're battery is grounded, and possibly have to ground the starter aswell. a lot easier than putting it in to find out. also, you should clean the copper armature where the brushes make contact, and then use a pic or skinny screwdriver to clean out each of the parallel lines between the the copper plates. it's important to clean those lines as they fill with debris and crud.
ghost civic
Jan 15, 2020 07:43 AM
Jordanl6112
Aug 3, 2015 10:19 PM
ghost civic
Jul 27, 2015 03:15 AM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
