lt80 sprocket change
Well I'm tired of fixing the 428 chain ,sprockets,and tensoner.I'm going back to the stock chain and gearing.If I replace the front sprocket
with an 11 tooth do I need to lengthen the chain?Thanks Al: |
Hey there,
That stinks. I've heard numerous people say that size chain works great. What size sprockets and what kind (aluminum/Steel) are you using? Is there a reason you are having problems, that you know of? Anybody else have any ideas?? The reason I ask is that I'm also looking at going with new gearing and going with #40 chain and a 13 to 15 front and 26 rear. You can get half links for that chain, which makes sizing it easier. Anyway, good luck [img]i/expressions/face-icon-small-happy.gif[/img] |
I didn't have any luck with the 40# chain. The half links kept breaking. The chain stretches real fast too. Just make you a roller and tension it that way. I've since gone with a good quality 428 chain and it didn't stretch near as fast as the 40 did. You may have to make a couple of different holes for the chain stretching. I drilled a hole thru the steel plate that that the chain runs by and put in a chain roller to keep it tensioned works good.
If you are talking about the mid-west mini chain tensioner I know what you are talking about. I think it is a really poor design. |
Originally posted by: Cougar205 Well I'm tired of fixing the 428 chain ,sprockets,and tensoner.I'm going back to the stock chain and gearing.If I replace the front sprocket with an 11 tooth do I need to lengthen the chain?Thanks Al: |
