Received Unison Desert Cat 90 Yesterday
Originally posted by: Sandragggen
The only thing I noticed that concerned me is that there is a spuratic rattling noise coming from under the clutch cover....the rear brake lever side. I mainly notice it when it is idling. When you give it gas, noise goes away.
Thanks,
JMiller
Thanks,
JMiller
I could be wrong but, I believe the rattling noise is the variator weights. At idle the rpm's aren't high enough to keep them seated in the ramps. Engine power pulses will shack them back and forth. The noise is just transmitting to the other side. I know on snowmachine drive clutches the weights can make noise at idle. Ride and enjoy
JMiller
So how did it do in the sand. Were you able to spin the tires, did the tires do okay. That is why I wanted to get my boy a new quad was so we could go to the sand.
JMilelr
#16
Thought about ordering a Desert Cat as well for the kids but was wondering if I could run it in mud, water etc... I live in wisconsin so there would be several different conditions to ride in. Thank you for any information you can give.[img]i/expressions/face-icon-small-confused.gif[/img]
#17
I would not recommend a cvt for mud or water.
#18
I just bought my son a desert cat 50 and looked over the manual from the link above.
Is the gear oil the only engine oil needed to be changed?
I added some 2 stroke oil to the resevior under the seat already.
I figure the engine oil needs to be changed on break-in.
