Eton chain tensioner
Old Oct 12, 2005 | 08:33 PM
cvc42's Avatar
Default Eton chain tensioner
Anyone put a chain tensioner on an Eton Viper 90?? Need info on buying one also.
Thanks!
Old Oct 12, 2005 | 11:05 PM
newnick's Avatar
I got one from HPD. It works great, and is highly recomended. Once you also get a good chain it's almost maintainance free.
Old Oct 13, 2005 | 01:14 AM
spike99's Avatar
To view how to install the HPD Chain Tensioner and modify its factory guard, surf: - Press Here -
For more info on the HPD tensioner, surf: http://www.hpd-inc.com/misc.htm
To determine which HPD tensioner that would bolt directly onto your E-Ton 90's Swing Arm, you may want to call them before ordering.
Hope this helps...
Old Oct 13, 2005 | 07:59 AM
cvc42's Avatar
Hey thanks! Has anyone figured out a way to seal a stator so it won't get wet??
Old Oct 13, 2005 | 10:45 AM
spike99's Avatar
Due to the design of the 2 stroke mini engines (which are scooter engines made for dry pavement), I haven't found a means to keep the water 100% out of their stator area. If you completely seal the stator, water won't get in, neither will air and over time, your engine's cylinder will over heat. For our Pred-90, I have implemented a few "tricks" that helped for us. They are:
1 - Sealed the large gap at the bottom of the engine case. For pictures, surf: - Press Here -
2 - Clean / Protect the stator assembly coils. For cleaning, I use - Spray on Brake Cleaner - And to protect it after its dried,
I use - Press Here - For us, these "clean & protect" one a year to reduce heat build up on the stator bobbins does work.
This might work for you too.
NOTE: When spraying the sealant, don't apply to the stator's pickup sensors / contact area. Need to ensure these items stay very clean and dry.
The best way to keep mud / crud out of the open stator area is ensure water stays BELOW the running board (as per factory recommendations). If mud / crud is your passion, you may have to "trade here in" and get a 4 stroke. They have sealed trannys and sealed Stator systems. I was looking at the Yamaha Blaster the other day. Cool looking machine. Bet that youth machine would take lots of water / mud abuse. Perhaps the "much better in the water / crud" Yamaha Blaster is your young rider's next ATV upgrade?
Hope this helps...
Old Oct 13, 2005 | 11:00 AM
cvc42's Avatar
Eton has the new 4 stroke 90 Viper on there website...Thanks for the info
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
raman8tor
Sep 20, 2015 07:35 AM
bvolks
Sep 13, 2015 12:57 PM
Minimod
Sep 10, 2015 09:20 PM
