Compression&Gas but no spark
Old Dec 20, 2005 | 11:55 PM
2manytoys's Avatar
Default Compression&Gas but no spark
Even if you bypass all the kill switches it wont start without the brake pressed. You cant bypass any of them anyways because it has to make a complete circuit The only kill switch is the rear tether, key and the on/off switch. The brake is a safety start not a kill.
Old Dec 21, 2005 | 12:02 AM
Joeski's Avatar
So in other words I need to connect that clip and I guess it was 2 wires back up on the left handlebar? I sorry to annoy you with the questions but a couple of other guys said to disconnect them because it may be a short an to bypass the whole ignition.
Old Dec 21, 2005 | 12:03 AM
Joeski's Avatar
Dag how many bikes do you have!!
Old Dec 21, 2005 | 12:15 AM
2manytoys's Avatar
I have my Polaris, Yamoto, Yerf dog and Powerwheels sportsman. Also have a meerkat50 on the yay. All the kill switches on this completes the ground circuit. There is no such thing as a short in a ground circuit. Any of these that are disconnected or activated causes an open circuit in the ground there for it will not start or it will die. . The Brake switch is a start safety only. It will NOT start without this pressed. Dont worry questions are not annoying. Thats what the forums are for.
Old Dec 21, 2005 | 12:26 AM
  #15
Joeski's Avatar
Thanks I have gotten rid of most of my toys. The only thing left is the sand rail. Do you have a wiring manual on your yerf because I was so fustrated that I just started pulling wires trying to figure out the problem? The website yerf-dog doea not offer any help. I even called and they said that they don't make them anymore and gave me a number of a sales person in Chicago. If you have the manual it would really help. Thanks Joe
Old Dec 21, 2005 | 12:32 AM
  #16
2manytoys's Avatar
I do not have a manual. I am a mechanic so it just comes natural to me. I may be able to tell you what wires go where.
Old Dec 21, 2005 | 12:41 AM
  #17
Joeski's Avatar
So basically what I need to do is attempt to rewire everything and try using the clutch or brake to start this thing? How is the performance on this thing, top end and power?
Old Dec 21, 2005 | 12:44 AM
  #18
2manytoys's Avatar
I really like the yerf. It is very quick with the top speed about 35mph. It can pull me around really well and I weigh 230lbs. It is just too small for my 7yo and too big for my 4yo.
Old Dec 21, 2005 | 12:50 AM
  #19
Joeski's Avatar
cool, I might keep after all if i ever get it started! So what you are basically saying is that the spark or current is cut from the plug if the left brake is not depressed? Are ther substitute parts for this brand like honda parts?
Old Dec 21, 2005 | 01:02 AM
  #20
2manytoys's Avatar
No substitute parts but they have been very reliable. yerf dog has been around for a long time. And yes in a sense current is cut if the brake is not pressed while starting.
