Moore LT80 motor kit
Old Jan 22, 2006 | 02:22 PM
Uptmor250r's Avatar
Default Moore LT80 motor kit
The clutch has a loose part that rattles when idle. When you give it gas, the rattle seems to go away. I took the cover off the clutch to see if the rollers are in good shape. The rollers look good. What else do I need look for? I was just wondering how often do I need to service the clutch. How long does the drive belt last with Moore motors kits? Do I need to look every three monthes or six monthes? I'm a bit confused so if you could shed some light, it would be much appreciated. Thanks.
Uptmor250r
Old Jan 22, 2006 | 07:33 PM
hateful's Avatar
we raced everyweekend and i tried to service ours once a week .the belts last along time .did you check the plastic sliders?.
Old Jan 23, 2006 | 01:47 PM
Hymis's Avatar
I have the same motor kit with a Trinity Pipe. I have that rattle sound too. I think its comming from the pipe. Check your pipe connections. Make sure the spring is good. Good luck!
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Whitelx1
Oct 2, 2015 10:55 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
