restricters on lt 80
Old Feb 10, 2006 | 02:06 AM
Kendoo67's Avatar
Default restricters on lt 80
Is it good or bad to have the exhaust restricter out , will it run better or worse ?
Old Feb 10, 2006 | 03:50 AM
WeLuv2Ride's Avatar
It's good to take it out. It will run alot better. The restrictor is a washer type that only allows a small amount of exhaust out, restricting flow and performance.
Old Feb 10, 2006 | 08:38 PM
katstoy's Avatar
It's good to take it out, otherwise it moves too slow. Make sure you play with the throttle limiter screw as once you take out the exhaust limiter you will get much more power. If your child is inexperienced, screw the throttle limiter down. As they get used to it and more skilled, you can unscrew the throttle limiter and they will get more power. Once the throttle limiter screw is out all the way, it's time to take out the limiter in the carbuerator. It is a brass ring that is about 1/2" thick and about 1/2" in diameter. Take that out and screw the throttle limiter in yet again, only to be gradually let out. With all the limiters out and the throttle screw at its widest point the LT80 gets lots of speed. My daugher's old LT80 could haul around uncle David who is at least a 200 pounder!
Old Feb 11, 2006 | 04:05 AM
Kendoo67's Avatar
Both are already removed from this quad, I just rebuilt the carb because the bike would ride good at high rpm and then lose power all of a sudden. I replaced the plug, checked the fuel lines and petcock, replaced air filter.
I dont know where to go from here. I hate to take the bike in to the shop , I dont know if it could be electical or not?
Thanks for your advice.
Kendoo
Old Feb 12, 2006 | 03:15 PM
katstoy's Avatar
What is specifically going wrong? I know with our 80 it was a constant battle to keep the air filter clean. If you let the filter go too long if effs up the carb. It seems that the filter on the 80 got dirtier faster.
Old Feb 14, 2006 | 02:12 AM
Kendoo67's Avatar
What was happening was it felt like aftergiving it full throttle it would fluctuate in power and sometimes bog down.
I regapped the plug and it is running alittle better.
Old Feb 14, 2006 | 01:45 PM
230conartist's Avatar
it sounds like its loading up. when ran at high r's its getting more gas than in can burn
if its running a little better with the gap changed the plug is probably burning the gas up a little better. it probably needs a jetting change or the needle moved.
slowgsxr97
Mar 18, 2022 03:40 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
ghost civic
Jul 20, 2015 12:36 PM
Mac2005
Aug 24, 2004 08:42 AM
trx430ex
Where to Ride
Feb 14, 2001 11:32 PM
