Help
Old Feb 20, 2006 | 10:24 PM
gamesmasterz's Avatar
Default Help
I think I originally posted this on an old thread....Can one of you help me??? About a month ago my son's Desert cat 90 just started losing power. He has ridden it three times since then and today it will not go unless you get off and walk next to it.Engine seems to run fine but the transmission just doesn't want to go unless there is NO weight on it...
Old Feb 21, 2006 | 01:40 PM
billl2099's Avatar
Default Help
is the desert cat a 2 or 4 stroke engine?
Old Feb 21, 2006 | 02:34 PM
Default Help
Sorry I forgot to mention it is a two stroke.
Old Feb 23, 2006 | 10:09 AM
billl2099's Avatar
Default Help
sometimes the carburator needs to adjusted,and can cause this type running, also it might be on the verge of having a piston seizure that would also act like what you're discribing, i would try adjusting the carb first and checking for air leaks around the cylinder base gasket.
Old Feb 23, 2006 | 10:22 AM
Default Help
I really appreciate it. I will try these out today. Thanks again...
