Air box mod for eaton 90 ?
Old Feb 22, 2006 | 09:18 PM
Bone1208's Avatar
Default Air box mod for eaton 90 ?
Are there any air box mods for the eaton 90, 05'? The air box has been a very big problem since we bought this quad. The location of the air box is probably the worst design i have ever seen. Any suggestions would be greatly appreciated.
Old Feb 23, 2006 | 12:03 PM
spike99's Avatar
If your Eton 90 Air Box has the same factory design of a Polaris 90, then I would also agree. The factory air box design is the worst design I've seen as well.
If mud / crud is getting into the factory air box, apply clear silicone around its overlapping edges. This helps stop water from entering into the air box. Cheap low cost fix that "might" help your situation.
Another trick is to remove the factory air box and install a Unifilter or K&N filter (with their respective outerware) under the front hood. For extra protection, oil down an old sock and slip it over the filter's outerware. Thus, double outerware protection. Run a flex hose from the carb to the newly positioned air filter. For a picture I like, surf: - Press Here -
Note: If you remove the factory air box and replace with a different air filter system (like the one above), you'll need to reject the Main Jet in the carb. The size of Main jet depends on the type of air filter you use, the size / wind drag of the flex hose and if you use an extra oiled down sock.
If one of the dealers on this forum have such a bolt on system, please advise. I've yet to find a bolt on system that fits under the front hood area.
Hope this helps....
Old Feb 24, 2006 | 03:11 PM
Bone1208's Avatar
Thanks for the advise Spike. I also would be interested in a bolt on air box mod.
Old Feb 26, 2006 | 09:22 AM
Bluetickracing's Avatar
Build 1 that's what I did. I put a uni pod filter in a waterproof shell and he can hit any creek or mud hole pinned wide open and never let on. It can be done. Just use your head.
Old Feb 26, 2006 | 02:52 PM
Bengen's Avatar
Do you have pics? I'm in the process of running ours up to the battery box under the seat. Electric start doesn't work anymore now that compression is up.
Old Feb 27, 2006 | 09:35 PM
HQR109's Avatar
check out my pic section. there is a picture of billy holts sons air box that i built. it uses hose from a wet vac, misc. pvc fittings and a uni pod filter.
Mark
kidstuff
Dec 23, 2013 03:05 PM
Strongbad1
Nov 1, 2011 08:12 AM
twindad01
Nov 9, 2010 04:36 PM
twindad01
Nov 7, 2010 05:54 PM
