Eton-50 Running lousy
Old Aug 8, 2006 | 09:44 PM
oldyeller's Avatar
Default Eton-50 Running lousy
Look into the tailpipe.The thing you see in it is the spark arrestor.I think it might have a bolt into the side of it or something to hold it in the tail pipe.
Old Aug 9, 2006 | 08:32 AM
newnick's Avatar
4 or 5 months in the shed. Did you drain the gas and use new gas?
Old Aug 9, 2006 | 08:52 AM
Ron27's Avatar
I will try it this weekend...I did drain the gas and put fresh gas in...but the old gas also had stable in it. So when i pull the spart arestor should i just brush it off? or do i use some kind of cleaner?
Old Aug 9, 2006 | 09:04 AM
theplayer's Avatar
I pulled the arrestor out and did not replace it.
Old Aug 13, 2006 | 08:43 PM
  #15
Ron27's Avatar
I took out the arrestor and you guys were all right...thats what it was...THANK YOU so much...Now the only thing is when it first takes off it boggs down and then takes off like a rocket..Any clues? [img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 13, 2006 | 09:29 PM
  #16
theplayer's Avatar
Now that's funny. My viper boggs down a little too, then takes off...I doubt it could be anything to do with the arrestor be taken out, but I'm not sure. Anyone know what might cause the hesitation when throttle is first pressed?
Old Aug 13, 2006 | 10:18 PM
  #17
Ron27's Avatar
haa haa...let me ask you a question when u hitt the gas quick does it sahl...
Old Aug 13, 2006 | 10:23 PM
  #18
theplayer's Avatar
No, it doesn't stall...just slight hesitation
Old Aug 13, 2006 | 11:43 PM
  #19
oldyeller's Avatar
You might try moving the clip up or down on the needle in the carburetor.You will most likely need to move it down a notch on the needle(towards the pointed end).This will give you a little richer fuel mixture in low and midrange...After removing the restriction of the spark arrestor maybe the pipe is allowing more air through the engine and you need a little more fuel to even it out again....I played with this on our viper and it made a big improvement in acceleration over the stock setting.This will all depend on temperature and altitude where you live though.
Old Aug 14, 2006 | 08:47 AM
  #20
theplayer's Avatar
Oldyeller,
does this involve taken apart the carb? Also, I have noticed that the black rubber hose going from the carb to the air filter box is not fully attached to the air filter box. It looks like the sealant that was there has seperated. The hose still fits into the pipe that is in the air filer box, but not sealed. Do you know what I can buy to reseal? thanks.
