Kazuma Dingo 250
Old Aug 11, 2006 | 12:26 AM
jhw's Avatar
jhw
Default Kazuma Dingo 250
I have a Kazuma 250 with about 8 hours on it. One day out riding and it stalled. No spark. I have a Kart with some of the same parts, and narrowed it down to the cdi. Replaced it and it still will not start. The choke seems to be working. Any suggestions would be great. Thank you.
Old Aug 11, 2006 | 10:12 AM
billl2099's Avatar
is the kart and the kazuma the same engine? did you try putting the kazuma cdi on the kart? if they not the same engine the cdi probably won't work, differant timing requirments. the coils should be interchangable.
Old Aug 11, 2006 | 09:42 PM
jhw's Avatar
jhw
Yes the same engine. swapped the coil from kart to quad and quad to kart. The quad would not start and the kart would with either coil. I have read about the cam shaft bolts needing to be replaced, what do you think about this.
Old Aug 11, 2006 | 10:11 PM
Radrob99's Avatar
this is a stupid question but did you check the plug and make sure the switch is on?
take the plug and put it in the spark plug boot on the kart and ground it and see if you get spark out of it.
Old Aug 11, 2006 | 10:31 PM
jhw's Avatar
jhw
Yes getting spark. The quad turns over and a light put sound comes out of the tail pipe but just wont fire up.
Old Aug 12, 2006 | 02:27 AM
Radrob99's Avatar
oh I thought you didn't have spark now that you have spark did you drain the float ( lil screw on bottom of carb) if yes what came out good or bad gas?
I would try to fire up with starting fluid just a little and make sure motor is turnig when you squirt it in.
do you have good compression in the cylinder ? could need valve adj. especialy if it pops.
you may have picked up dirty gas to if so you will have to pull carb to clean jets
one of my buddies put diesel in his couldn't figure out why it wouldn't run when I pulled the carb there was diesel in it he blamed it on one of his driver's at the shop
(haha) I said
Old Aug 12, 2006 | 02:35 AM
Radrob99's Avatar
AND ALWAYS BE CAREFUL WITH STARTING FLUID IF YOU PUT TO MUCH ON AND IT BACKFIRES IT WILL CATCH THE ELEMENT IN THE AIR CLEANER ON FIRE AND THEY DONT LIKE TO COME OUT WIN THERE ON FIRE TRUST ME BEEN THERE DUN DAT PLUS IT MELTS THE CRAP OUT OF THEM. JUST BE CAREFUL
Old Aug 12, 2006 | 10:06 AM
jhw's Avatar
jhw
Getting spark because i replaced the cdi. But still wont start. Will get starting fluid and try. I have drained the gas through the bleeder several times. what do you mean by good or bad gas? How do i tell?
Old Aug 12, 2006 | 02:51 PM
Radrob99's Avatar
if it looks like crap, smells like crap. taste like crap, guess what it is ? ha ha
what i do is drain some out in a clear water bottle and make sure it looks good not real brown and a bunch of junk in it. I also go by smell
do you have good compression ?
its probably your carb got some dirt, if it runs on starting fluid the jets are probably dirty
get some start fluid and let me know what happens
these bikes have auto choke and sometimes that can cause problems to but usually it still will start if its the choke but will run like crap
Old Aug 12, 2006 | 02:55 PM
billl2099's Avatar
the biggest problems with the 250 seens to be the wire connectors to the coil come loose and act like you describe, eaither replace them or the very least recrimp them
