eton70cc
Old May 23, 2007 | 09:18 PM
arrowone's Avatar
Default eton70cc
yes what can i do to get some more speed out of a stock 2005 70 eton? are there any factory limiters that i can remove cdi box already turned up looking for alittle more speed my son races in the 90cc class and beats most of them from the start but then they take him by the 2 or 3 lap i dont want to buy any mods yet as i would like to get him a hetrick machine for next season any help would be very valuable
Old May 23, 2007 | 11:14 PM
oldyeller's Avatar
Default eton70cc
It's going to be tough to gain any more speed without buying any mods for it..Especially top speed which takes more power..On our 90 I have installed a UNI filter and rejetted the carb.Also installed some boyeseen reeds..I put some lighter wieghts in the variator which helps it take off much quicker but I had to tune it carefully to meet and finally exceed the stock speed by 1-2 mph..It's fairly easy to make it accelerate quicker but top speed is a little tougher..You could try a different sprocket if your rider isn't too heavy..Thats next in my testing as well.
Old May 24, 2007 | 01:24 PM
arrowone's Avatar
Default eton70cc
yes i see in alot of the questions here some of the machines have factory restrictors in place is there any on the eton 70? like the washer they talk about on the clutch assembly ? if not i guess i will get pipe filter and clutch set up has anybody dealt with lakesmotors sports here in michigan ? i have heard some bad some good around the tracks we race but most of the parents i talk to at the races for my sons dont even ride them selfs so i would like to turn you people in this forum for help thank you all
Old May 24, 2007 | 09:04 PM
oldyeller's Avatar
Default eton70cc
As far as I know the only restrictors are the cdi which can be adjusted and the throttle screw..There were no other restrictors on our 90...I haven't heard much about lakesport but one of the few comments I heard was negative so take that for what its worth...For proven performance WRH racing or Hetricks should be able to get you going.
Old May 24, 2007 | 09:29 PM
arrowone's Avatar
Default eton70cc
thank you for the info i will just make due with what he has till we get him another for next season his younger brother runs a 40cc eton in the 50 class and does very well against the bigger machines again thank you
