broken axle
Old Sep 14, 2007 | 05:23 PM
  #21
Noxzema's Avatar
Default broken axle
elas123 I will call them on tuesday. They want me to call the plant? they did not give an answer through email.
thanks Billl2099, cowgirl send PM
thanks. broken axle heart
Old Sep 14, 2007 | 05:29 PM
  #22
elas123's Avatar
Default broken axle
It is a huge warehouse i have been their many times!!!! did you look at the pictures off their website to see if they look like yours? They sell cheap quads(really cheaply made) but they do have better prices on stuff than raceway. i have compared parts that look similar (maybe they are a little different) but they are more expensive through raceway. i hope it works for you and you get it cheaper!
Old Sep 14, 2007 | 05:43 PM
  #23
Noxzema's Avatar
Default broken axle
the axle on their web page does not look like mine, probably won't work, they don't stock Kazuma
Old Sep 14, 2007 | 05:48 PM
  #24
elas123's Avatar
Default broken axle
i thought that it might be the same axle. it was worth a try!
Old Sep 14, 2007 | 09:27 PM
  #25
Noxzema's Avatar
Default broken axle
Thanks, I'll try anything. I should have gone with my insticts and not bought Chinese, i did know better but I was being Mr. Cheapo! This is what it comes down too, begging/searching/whining on Forums..DOH!
Old Sep 14, 2007 | 10:39 PM
  #26
elas123's Avatar
Default broken axle
i hear you. my wildfire 110 is broke down due to the engine is knocking real bad in neutral. let see the left from hub broke will ride causing the tire to fall off. the idiots left live power wires hanging there and i didnt know what they were for causing a short then causing the case to caught fire!!!. yes the wire caught fire under the gas tank.i had to reach in and start pulling the wires and fire out from under the quad! i got it out. they gave me new wiring harnest. oh did i mention that they changing the harness connector to different ones? i had to spend 7 hours figuring out what everything did and rewire it the right way. then lastly the engine started knocking bad. lesson here RIDE=BREAK!
Old Sep 15, 2007 | 09:19 AM
  #27
Noxzema's Avatar
Default broken axle
i hear you too! This is actually my second 150, my first one had a main seal oil leak right from the start, which would have required me to take apart the whole engine to fix. After months of bickering i was able to get the company i bought it from to send out another quad and return that one. Then my second one after a few months blew out the tranny! It took 4 months to get a new one!. then my front end started getting loose so i ordered control arms, 2 month wait! Now Im on the axle deal. Plus countless other small things that im able to fix myself. I dont ride far from home because I had to push it home a few times, I go out alone.
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
1000gade
Sep 9, 2015 04:41 PM
