Kazuma Meerkat 50/90 Newbie Questions
I need the rubber air intake tube that runs from the carb to the air box. Can I use something else. The cheapest one I have found is $24.00 Also I need a gas tank too I found one of those for $44.00 Also does anyone make pink plastic for these? I have a owners manual for a Meerkat 50 and I have a Meerkat 90, is there anything I need to know that is different between these atv's. Thanks for all of your help...
If you need any parts check out Raceway. There is nothing different between the 90 and 50 except for the motor. They do make pink plastic. You should be able to use any rubber hose that will fit over the carb and into/onto the filter box. Most just like to use a clamp on filter. Like K&N. You can go to the k&n site and go under uni filters. Know the size of your carb flange and how much room you have. You can match a filter that will fit. I did it with mine but I no longer have it any more so I cant give you the number. I will look for the box adn see if I can get the number.
