Stator issues...Different wiring colors.
Old Nov 30, 2007 | 10:29 AM
custom1106's Avatar
Default Stator issues...Different wiring colors.
I'm having a little trouble wiring up this new engine after the swap. I picked up a 110cc semi auto to replace my 90cc auto in my baja wilderness utility quad.
the stators are completely different, the original 90cc has a stator with 6 coils, and the 110cc has 2 big coils. I can not use the 90cc stator on the 110cc, because the outer black pickup on the 90cc stator is in the wrong place so I don't get spark. The wiring colors/plugs are different between the two also.
The original 90cc stator has:
green with white stripe
blue with white stripe
black with red stripe
two solid yellow wires
The new 110cc stator has:
solid green
blue/white
black/red
solid yellow
solid white
The atv has:
Green/white
blue/white
black/red
solid yellow
solid orange
I don't want to hook up the wrong wires and fry something, I need a little guidence here. Any help would be appreciated!
Old Nov 30, 2007 | 02:06 PM
Jessie_atvruns's Avatar
Just for your reference
The original colors of wires are;
Green for Ground
Blue/White for Pulse generator to be connected with CDI
Black/Red for Exciter to be connected with CDI
SLD Yellow for Battery Charge to be connected with Regulate-rectifier
SLD White for Battery Charge to be connected with Regulate-rectifier as well
Pls check the components on ATV, I guess you could find the adequete wirings.
But the easiest and safest way is to swap Fly wheel and Stater at the same time.
Good luck!
Old Nov 30, 2007 | 11:16 PM
custom1106's Avatar
Made up a temporary harness to connect everything without cutting wires...matched colors...pushed the button and it fired right up. Thanks a bunch!
slowgsxr97
Mar 18, 2022 03:40 AM
bradco
Aug 21, 2015 08:11 PM
Atvnewb88
Aug 19, 2015 02:22 AM
Atvnewb88
Aug 13, 2015 06:48 AM
