best brand carb?
Old May 22, 2008 | 09:13 AM
red123's Avatar
Default best brand carb?
I posted a while back with some carb problems on my sons 70cc red cat i took the carb off and went to clean it i found the float was broken i would like to put on a better carb mikuni ? not sure looked on ebay and could only find the same thing that is on it h@k or something like that but i am afraid i will have the same problem. any help on finding a new carb would be great my son is pretty bumbed out seeing his wheller deadlined.
Old May 22, 2008 | 10:59 AM
chineseatvmechanic's Avatar
mikuni and keihin both have carbs that will fit, your 70cc quad takes a 16mm, you should beable to install a 19mm without any problems, the 19mm is what they install on the adult size 110cc quads
Old May 22, 2008 | 11:58 AM
balanis03's Avatar
do you know if the Jetmoto will increase HP if i put a new carb and switch to Mikuni? and i believe thay have a 30MM carb for th 250cc is that correct?
Cole Hadden
Jun 15, 2025 09:05 AM
micheleLeigh
Jul 12, 2015 02:50 AM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
