I need help
Old May 28, 2008 | 09:41 PM
IM4MIKIDS's Avatar
Default I need help
I recently bought a cobra 60 I believe for my 8 year old son we have rode it a few times runs great the problem is i put it in the garage for storage and woke up from gas fumes come to find out there is a puddle of gas dripping from a line that is bracketes on to a bvlack thing guessing the black thing is a carburator??? Im sorry i have no idea I looked for something to be missing I COULDNT FIND A THING I PUT A SCREW UP IN IT AND IT STOPPED DRIPPING WE HAVENT RODE IT SENSE PLEASE LET ME KNOW IF YOU CAN HELP THANK YOU
Old May 28, 2008 | 09:57 PM
grump's Avatar
Default I need help
If it is the carb the float could be sticking and it pouring out of your overflow line, Is the fuel valve (petcock) closed?
Old May 28, 2008 | 11:52 PM
fourwheeldrive's Avatar
Full Time DAD!
Default I need help
Sounds like what grump said about the float being stuck. That is, unless one of the fuel lines have rotted or disintegrated and came apart/loose. If the machine has a petcock (fuel on/off valve), you should always turn it off when in storage. If it is the overflow tube, sometimes you can take a small screwdriver handle and tap the bowl on the carb to dislodge the float needle and stop the flow of fuel. If this doesn't work, the carb will have to be removed and cleaned.
If the fuel line has come apart/loose, you will need to reconnect and/or replace the line.
Old Jul 3, 2008 | 12:15 AM
kjohnracing's Avatar
Default I need help
Does this quad have a clutch or is a automatic. It sounds like the float is stuck,if i know what motor you have i can tell you what parts you need.
