HELP ATV WANT GO
PLEASE HELP ME I SPENT 300.00 TODAY TO HAVE ATV FIXED I COULDNT SHIFT GEARS BEFORE OK THATS FIXED NOW .
OK NOW THE 4 WHEELER DOESNT WANT TO GO NOW THE TECH SAID IT NEEDS A BEARING IN THE REAR END WHAT IS HE TALKING ABOUT
We need a lot more info, what do you mean "wont go"? I'm guessing he is talking Rear axle bearings?
Will the motor run? When you let out the clutch what happens? What ATV exactly is it? I have never heard of any 260cc atv in any brand! Post or find a picture of it on the net so we know what it is!
he's talking about the rear axle housing bearing, these are the bearing that hold the axle in place, to check these yourself, rise the rear of the quad, rotate the wheels, if you can't rotate the wheels, then if it's chain driven remove the master link on the chain , remove chain, then try to rotate the wheels, if you can now, then your mechanic screwed up on your transmission. if you still can't rotate the wheels or if their's some horrible noise like grinding going on then more than likely it's the bearing. you can replace the bearing yourself or pay to have it done. if you decide to do it yourself it takes appox 2 hours, first time. if you pay to have it done expect to pay around $200 maybe a little less depending on the dealer and his labor rates.
