DRX 50 top end tech
Does anyone have the cylinder head tourqe spec's for a water cooled 2008 drx 50. I am going to rebuild the top end for the first time and could use some tips.
We have raced 2 seasons on this bike and it is stock except the wheels and air cleaner |
DRX 50 top end tech
Welcome to the forums.
I torque the head nuts to 115 inch pounds. |
DRX 50 top end tech
thanks that will help alot, Is there a tech site that I could go to for referance for other stuff like omitting the oil injection and removeing the oil pump gears. My son loves to get the hole shot.
DRX 50 top end tech
atvriders.com (mini section)
miniatvtech.net |
DRX 50 top end tech
thanks, in the kit that I got it has the piston, two rings,an ochtagonish ?spring ring thing?, wrist pin, clips and a couple gasket . What is the ochtagon springy thing that was not on my stock set that was on the bike.?
DRX 50 top end tech
If it's what I'm thinking, the LT80 stock bore piston has that thingie too. You should find out which ring it goes under. I'm thinking the top ring.
DRX 50 top end tech
I got it back together and did not use the thingie but broke one of the rings and ended up putting the best use ring out of the old set. it rens great. At half throdle it has almost the same as before. Cant wait to open it up.
