low end bog with new pipe
Old May 28, 2009 | 06:20 AM
AIRMOBILE101's Avatar
Have you tried to clip the carb needle up one notch?
Old May 28, 2009 | 08:12 AM
oldyeller's Avatar
Originally Posted by hotblooded
It just seems that you need a higher engagment, in the video it just sounds too low for a pipe that relies on rpms. The main red spring is the shifting spring so that won't effect the engagment, I would get a set of stiffer of the three little ones and have it come in harder.
I agree that is how it sounds(like its not coming in high enough)..I have already installed the 3little red springs in the clutch..
I did try moving the clip on the needle(up and down) and it was much worse either way..
I have ordered some jets so we will see what effect they have..
Old May 28, 2009 | 11:18 PM
hotblooded's Avatar
What is the engagment of the red springs? I would personally go one set higher and I truely believe that would take care of your problems. With the work that you have done and the pipe you have created a more difinitive power band and you need to get close to that on engagment. You may even have to sit on the tank a little to keep down the front.
Old May 29, 2009 | 11:21 AM
oldyeller's Avatar
I talked with a guy at hetricks again..He said the torsion spring was a 1500 and the three red engagement springs were 2000 rpms and supposedly the stiffest you can get...He said the clutch shoes on the etons were heavy and that I was probably not getting a high enough stall speed even with the red springs...He felt a set of light wieght shoes would fix the problem so I ordered a set...Hopefully that will do it...
Old May 31, 2009 | 12:32 AM
  #15
hotblooded's Avatar
I am not saying they are wrong but it really doesn't sound like 2ooo, let us know what happens. This will be good info for a bunch of us.
Old Jun 3, 2009 | 11:47 AM
  #16
oldyeller's Avatar
Ok so I got the new light wieght clutch from Hetricks installed today..Bottom end is improved but it almost seems like its shifting up too quick now? Bottom video is with the new lighter clutch..
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
bvolks
Sep 13, 2015 12:57 PM
