Koplin 50cc (disable gov/rev limiter)
Old May 28, 2009 | 07:14 PM
kawadoggy's Avatar
Default Koplin 50cc (disable gov/rev limiter)
Help, i have a 50cc Koplin that i would like to get full throttle out of. I have adjusted the throttle limiter but something is still governoring the bike. Not sure if the CDI is holding it back, if any one has any ideas on how to disable it would be appreciated.
thanks
ds
Old May 31, 2009 | 04:33 PM
optic2010's Avatar
i have found out there are a few different types of speed limiters. The throttle ones you have already taken care of, also air flow restrictors and even a spacer in the carb that limits the effect of the throttle(you can have full throttle on the actual throttle but not on the actual engine). Check you air filter to see if there is an air restrictor plate first, if not then check the carb slide to make sure there isn't a spacer limiting the travel, then if you have to buy a cdi without rev limiter they are about 80$ in canada
Old May 31, 2009 | 09:05 PM
kawadoggy's Avatar
Thanks for the help.
ds
Old May 31, 2009 | 09:17 PM
optic2010's Avatar
out of curiosity please let me know what you find.
Old Jun 6, 2009 | 08:02 PM
kawadoggy's Avatar
i changed the jetting and it really pepped this little rig up, no bog.
ds
Old Jun 17, 2010 | 02:25 PM
lilray's Avatar
hay up i gota can am 2006 50cc and im trying to disable the rev limeter but i dont noe wich wire to cut plz help
Old Jun 17, 2010 | 07:41 PM
kawadoggy's Avatar
lilray
As mentioned in previous thread the 50cc i have was a simple jet change and some minor air cleaner mods (breathe) was all it needed. I thought it had governor or speed limiter but they restricted the power with less fuel (smaller jet). I increased the jet size **** allow more fuel and modified the breather so it could get more air and it cam alive. hope this helps.
Kawadoggy
Old Jun 17, 2010 | 08:16 PM
lilray's Avatar
that helps but im sure thay have a rev limiter
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
Alex G.
Sep 19, 2015 06:34 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
