ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Kids Quads (https://atvconnection.com/forums/kids-quads/)
-   -   Rolled Kfx80 in river now won't pull?? (https://atvconnection.com/forums/kids-quads/343655-rolled-kfx80-river-now-wont-pull.html)
bdcamp80 Apr 19, 2012 01:09 PM
I have drained water I was able to find, changed plug and air filter. Runs fine now but won't pull. Did not have this problem before submarining????
Jammies Apr 19, 2012 03:30 PM
Runs fine but won't "Pull" as in the quad seems to have no power with the wheels on tr ground?
Have you cleaned the carb after taking in all that water?
bdcamp80 Apr 19, 2012 05:17 PM
Motor revs but quad doesn't move. I just pulled clutch clover off and found some water maybe that was the cause. Will know more when I get it back together.
Jammies Apr 19, 2012 05:39 PM
Sounds like a good start, that water sure wasn't helping anything :D
Try rolling the quad while it is running, then try giving it gas and see if it will take off.
Hopefully LT80 will chime in, the KFX80 is identical to the LT80, an he sure knows his stuff about these little quads.
95wolv Apr 20, 2012 05:47 AM
With the belt cover off, try revving it up to make sure the front variator is expanding and grabbing the belt, could be the rollers got stuck when it rolled, or the belt is just that wet, even a little film of water will keep them from moving, but usually all it takes is a little revving to dry out the belt housing after you drain it and it will go again. But I would jack up the back tires and rev it up with the cover off to make sure the belt is being grabbed, without that, nothing will move.
LT80 Apr 20, 2012 08:16 AM
I think it'll be fine once dried out.
bdcamp80 Apr 20, 2012 10:48 AM
Ordered a new gasket just waiting to put it back together. I'm sure the water was causing something to slip. I cut the clutch shoes down to 180 while I had it apart trying to get a little more low end out of it. The rollers appeared fine going to leave those in for now.
bdcamp80 Apr 20, 2012 04:41 PM
Saga for me continues... Put it back together and now sometimes clutch engages but mostly the motor revs and quad doesnt move. I noticed when I turn it off it (clutch) sounds like it's engaging at very low rpms. I pulled it back apart and ideas???
Also the belt was turning while motor was reving bit wheels weren't turning.
LT80 Apr 21, 2012 09:34 AM
Could the rollers have fell out of place durring installation?
It's deff in the clutchs if the motor is running correst.
95wolv Apr 21, 2012 09:52 AM
Jack........are you still sneaking into peoples garages and sabotaging their LT80s ?....stop doing that and let him fix it.......LOL.
But seriously...you say the front clutch is closing on the belt and turning it?, is the back clutch spinning up also? I don't know how the transmission is set up, but is it possible the shaft for the transmission is not turning? is there a key on the shaft that could have sheared so the secondary clutch is not turning it? If both front and back clutches are spinning up, and closing on the belt, and you can see the belt rising up in the sheaves as they close, it would have to be a problem of power getting to the transmission.
© 2026 MH Sub I, LLC dba Internet Brands
