Lt80 Clutch issues
Old Apr 20, 2013 | 07:13 PM
  #21
SpyderV8's Avatar
It's .5mm over, shaved head .030, I raised exhaust port .060 or 1.5mm, I didn't raise or widen transfers, just knife edged the bottom and tried straighten best I could without getting to cylinder wall. Widened exhaust about 1.5 each side or 3 wider and straightened it all way out to end to match pipe donut. Opened up reed cage as much as possible to keep divider which is knife edged, and keep oring at opening. Stock pilot jet but 90 main. Still feels fat to me when reving up high. I'll get comp soon as I can. But it's up there it feels like
Old Apr 22, 2013 | 04:32 PM
  #22
SpyderV8's Avatar
Ok took compression reading on a cold cylinder with throttle wide open and got just over 150 psi. I knew was high but didn't think that high so I got my expensive snap-on from work and it read 153. I also put a 12 tooth front sprocket on and when boy on it it seems ok but if I get on it it'll rev pretty hard while trying to take off. It will go but I don't like the slipping. It's probably way to high gear ratio for me, it's slipping pretty hard, in the rear clutch I think too as no belt smell and I could feel heat back there when I shut it off and layer hand on case, may not be most accurate but it was way hotter than up by engine.
I just thought I'd give you a heads up on it, comp that is. I'm running 92 octane, and 32:1 on oil mixture yamalube R which I'm thinking is synthetic, (got lots due to my blaster).
Thanks
ghost civic
Jan 15, 2020 07:43 AM
Mikesohio
Jul 26, 2015 10:51 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
Wnthunting
Jul 9, 2015 03:02 PM
