Predator 90 kick start
Take the nut off,leave the claw washer on,install the fan wheel or starter clutch as it's called,washer then the original nut.Best to use an air impact on this as I remember it's tough trying to get this done with a ratchet. This should get you fixed up as far as the kick starter. No changes in parts from the 2001-2006 two stroke models.2007 they went to 4 strokes and still had kick starters,but internals were different.
#15
#16
That shouldn't matter on #30,but no harm in trying. All I remember is that there is very little room to get the little starter clutch(fan wheel as you call it) washer and nut back on. That why I had to use an impact. Again I hope this is a Polaris engine,since it didn't have one to begin with.
#19
All I can remember off hand is the vin # started with RF series,but as far as engine serial numbers,I never paid that much attention as to what and where they were located.Just remembered the engine serial number is behind the gear case fill plug.Don't know if that helps.
Last edited by old polaris tech; Mar 6, 2017 at 10:12 AM. Reason: engine serial number
