Modified 90cc to 100cc Polaris predator stalls after 1/4 throttle stumped
Ok first I got this thing in a basket case. No spark. No knowledge of 2 stroke but that's how I learn. It was cdi. So hear is what I did originally. First gutted all wiring. I needed to learn plus in my understanding what can go wrong will. I rewired a Chinese cdi from the motor to the coil and set the kill on the horn button. Like I said basics. Clean and tuned carb. Custom air cleaner. Kick start only. It was fast in the end. I'm 300 lbs. I smoked 150 lb ppl on there fully set up machine's. 2years strong finally one winter our she'd let go had to keep it outside and water was the killer. Seized with rust. So I ordered a big bore kit. New carb coil cdi all aftermarket but nothing I haven't ran before. Also no oil injection I mix my gas cut the cable it's been this way sense I first got it. 50 to 1 mix. Got it together ran it I get about half throttle then bog to stall. Order a jet kit 80 85 90 jets all do the same. Half throttle to stalled. Idles fine tons of power threw idle mix after that stall. But if I slap choke the carb with my hand I'll get tons of power for a second then stall. Exhaust on or loose no change. Restricting air to carb gets worse. Plug new. Reed's new. Boots good. I'm stumped.
"Custom air cleaner" sounds like the problem. If you have the stock air box and snorkel try that first. If you don't have one you can get one cheap on ebay.Either that or sounds like you still need to play with jetting.
Solved it
With enough thinking and looking at the carb I got it. I pluged the choke port completely. Never used it anyways. Popped the 90 jet in it and caped off one of the ports and bam full power. Running a bit ritch but I'd rather that then lean. So a quik fix option. Is there. Ill post pics of this modified machine.
Video link of machine
https://youtu.be/aDoGjAqr-yE video and explanation of what's on this beast lol
Srry this is the link lol
Might be stupid me,but copy and paste to you tube doesn't work.
Low rpm's. Something is holding it back.
I'd guess the small size snorkel. Maybe that pipe. Maybe that screw in the front of the carb..LMAO |
Originally Posted by LT80
(Post 3367126)
Try that
(Post 3367123)
It did for me but I can't make it work again.
