Cannibal Question?
Old Dec 27, 2006 | 12:00 AM
Benfica90's Avatar
Default Cannibal Question?
I just recently bought a 2002 Cannondale Cannibal.. It ride great but the only problem is when i stop the bike stalks, Any suggestions? DO you think if i turn the idle up a little more it will fix that problem..
Old Dec 30, 2006 | 05:09 PM
claas900's Avatar
..If idleing to low is the problem then that will if it. Do you know what its idleing at? go to cannondaleriders.com for more info
Old May 29, 2007 | 03:15 AM
joshk1234's Avatar
could this problem be attributed to the brake booster? are fluid levels for the brakes all adequate?
Old Feb 5, 2008 | 09:19 PM
19dan1988's Avatar
Does it idle after you start it or when it is just sitting there when you dont give it any gas? P.S. i had a cannondale cannibal and they are high performance and high maintanance. Unless you are planning on dumping your life savings into it I would suggest selling it.
Old Mar 25, 2008 | 07:25 PM
smitty911's Avatar
19Dan1988,
In several of your responses you have suggested selling it or spending your life savings. How about learning about the quad and doing a little Preventitive Maintance, your cost will go down accordingly. This would of course apply to ANY manufactures quad.
Now to the question, the motor should Idle around 2,000 rpm. You might also check to make sure your clutch is properly adjusted.
Smitty
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
